Hi.
Soon I'll be changing out my reference r9 290x card (my ears are grateful) for something else. I was wondering what impact the open air cooler that most non-reference cards sport would have on nearby expansion cards (I have a small raid card (cheap) and a larger sound card (not cheap) under that, pictured below). Would the temperatures be damaging with a hot running card like a 290x or 390x (just as a worst case scenario)?
And yes, there are sticky labels on the graphics card, don't judge me it looks fine from where I sit :P
CPU: Intel Core i7 3820 @4.4GHz Motherboard: Intel DX79TO | Graphics Card: XFX RX 480 RS RAM:  16GB Corsair Vengeance LPX DDR3 @ 1600MHz Sound: Asus Xonar Essence STX | Storage: 1x Kingston UV400 120GB | 1x 3TB Seagate Barracuda | 1x WD Green 1TB | PSU: Seasonic S12II 620W | Case: NZXT S340 White | Cooling: NZXT Kraken x31
https://linustechtips.com/topic/684269-open-air-cooler-question/
temps shouldent be a problem, you seem to have ample space in your case
Builds:
https://linustechtips.com/topic/684269-open-air-cooler-question/#findComment-8790444
Open air cooler pushes the air in the inward direction (like the reference card). So the hot air is not directly hitting the other cards (as you might have thought) out of the open air cooler gpu. Thus there is no possible way of damaging your other cards in a mid size pc case.
https://linustechtips.com/topic/684269-open-air-cooler-question/#findComment-8790483
https://linustechtips.com/topic/684269-open-air-cooler-question/#findComment-8790489
