Full budget? What are you going to use it for? MORE INFOOOO!!
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/68420-my-pc-build-im-poor/#findComment-937390
I already bought it it was the best i could do, i would like opinions on my choices, or if i'm stupid and picked the wrong stuff.
It's decent enough. I'd recommend adding a ssd down the line when you can. It makes a world of difference.
https://linustechtips.com/topic/68420-my-pc-build-im-poor/#findComment-938994
good build, I would have gotten a better PSU for that price though.
also I'd try my best to get a graphics card with at least 2 GBs of Vram but if you couldn't budge your bidget the build looks fine, I'm loving the biostar board.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/68420-my-pc-build-im-poor/#findComment-939098
Was gonna add some stuff, but if you maxed out yo budget, thats a fine mighty build. Could have gotten the same-ish GPU for less, and could have upgraded that board a bit. (http://www.newegg.com/Product/Product.aspx?Item=N82E16814131488&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
I know you bought it, ignore the links if you want. Or a 650 Ti which is better and cheaper too. I think.
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
https://linustechtips.com/topic/68420-my-pc-build-im-poor/#findComment-939846
https://linustechtips.com/topic/68420-my-pc-build-im-poor/#findComment-939869
