Hello all, I hope you are having a wonderful day.
Now, I plan to do some upgrades this Christmas and I'm looking for some recommendations/suggestions as to what I should do.
Here is my current build: http://uk.pcpartpicker.com/list/FBcDzM
1. GPU:
 - Currently undecided between a 1060 and 1070, I'm thinking of possibly switching to a 1440p monitor some time next year which leads me to the 1070 but It is a rather large price jump!
2 CPU:
- Does this need updating? If so would something such as this suffice https://www.amazon.co.uk/Intel-Core-Skylake-Processor-i5-6500/dp/B010T6CWI2/ref=sr_1_1?s=computers&ie=UTF8&qid=1478007333&sr=1-1&keywords=i5
3. RAM:
- All I have to mention on this is the fact I will probably upgrade to 2x8GB sticks of RAM.
This is mainly a gaming machine and I play a range from mmo's to shooters.
Thank you for your suggestions!
https://linustechtips.com/topic/684171-upgrade-help/
There won't be any issues with bottlenecking for a 1060/1070, watch this video for an example (though that is overclocked, so you might not get the same performance)
That CPU will still be good for quite a while, i'd only upgrade it if you feel you want a newer one.
https://linustechtips.com/topic/684171-upgrade-help/#findComment-8789424
1. gpu would go for the 1070 if you are running AAA titles on 1440p but if you dont play AAA titles that much the 1060 would be sufficient
2. cpu no need to be upgraded, if you really want to, go with the i7-3770k
3. ram yep probably will upgrade
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/684171-upgrade-help/#findComment-8789425
