System temperature 89-90C
Go to solution Solved by MisterWhite,
Faulty ram stick
My old computer started restarting when browsing internet or playing a game. Now after booting into windows after like few minutes in firefox it restarts. I checked cpu temps, never higher than 50C (while in firefox). Although in bios and hwMonitor there is a section called System Temperature and it hovers between 89-90C, not sure what it represents. Any help would be appreciated.
i5-4690k, R9 380 4gb, 8gb-1600MHz ram, corsair vs 550w, astrock h97m anniversary.
https://linustechtips.com/topic/684168-system-temperature-89-90c/
It's the chipset on the motherboard. Depending on how old and what type of computer this is, it might be split onto two physical chips generally called north- and southbridges. There should be a heatsink on them which are now probably just dusty or the TIM under it has dried up. Northbridge is usually close to the CPU and southbridge somewhere more to the south.
i can hold my finger on northbridge heatsink
Thoroughly clean out the inside of the PC. sounds like you have a bad sensor.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
