Hello, so I am new to pc building. I never build a pc before. So, I checked all my parts at pcpartspicker.com and I found no issue whatsoever with my build. But I know that I can't trust 100%. So, below are the parts list.
http://pcpartpicker.com/list/TZb98K
Well, I am only curious about the ram though. If there are any problem on the ram, please tell me. Because, I want 2X4 GB of RAM. Thanks for helping me.
https://linustechtips.com/topic/684058-pc-building/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler  ($16.89 @ SuperBiiz)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($72.98 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1600 Memory  ($70.92 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.33 @ OutletPC)
Video Card: MSI GeForce GTX 1060 6GB 6GB GAMING Video Card  ($284.98 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Power Supply: Cooler Master 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($60.98 @ Newegg)
Total: $834.06
Generated by PCPartPicker 2016-11-01 02:33 EDT-0400
Rebuilt your build. I added more RAM, corrected parts that didn't have a pricing, etc.
https://linustechtips.com/topic/684058-pc-building/#findComment-8788352
http://pcpartpicker.com/list/D6w2r7
changes:
cpu; 6700 > 6600k
cooler; hyper t3 > hyper 212 evo
motherboard; micro ATX > ATX
ram: 8gb > 16gb
storage: added SSD.
video card: GTX 1060 > RX480. say what you'll say, there was a combo deal making it cheaper than the 1060, and you keep your red/black theme.
case: changed to one I've actually heard of.
power supply: modular > fully modular.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/684058-pc-building/#findComment-8788430
Total: $834.06
well, I am wandering what Intel XEON for? because I wanted to use my PC to edit and render the videos.
https://linustechtips.com/topic/684058-pc-building/#findComment-8794912
changes:
cpu; 6700 > 6600k
ram: 8gb > 16gb
storage: added SSD.
well, i5 are good for rendering video? i am amateur video editor and what say you?
https://linustechtips.com/topic/684058-pc-building/#findComment-8794918
Xeons and i7s are on the same level. Xeons just don't have iGPUs, but you're already buying an a dedicated GPU.
I just switched you from an i7-6700 to an Xeon 3e-1231v3 because it's $70 cheaper and a tiny bit less powerful.
https://linustechtips.com/topic/684058-pc-building/#findComment-8797562
thanks for your help!!! :)
https://linustechtips.com/topic/684058-pc-building/#findComment-8800691
