I want to build a new computer for the purposes of folding. I don't care about any other performance... I can always switch things up for gaming or editing at a later time. I don't have a particular budget. I want the best dollar to folding performance so I won't spend $5000 the most powerful GPU ever but I will spend more if the card is a better value than a cheaper card.
That's about it! Thank you :)
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/683919-best-wu-folding-machine/
what does folding benefit from the most? good GPU or CPU, and how well does is scale over cores? if you give me that then i might come up with something, tho there is probably someone who knows it better lol
Builds:
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786868
From what I know, folding is more CPU intensive than anything else.  You will likely want to overclock the processor for better performance.
I recommend something like a 6700K or a 6800K.  The 6700K is faster in terms of core clock speed, but the 6800K has 6 cores and a slightly lower clock speed.
6700K-http://www.newegg.com/Product/Product.aspx?Item=N82E16819117559
6800K-http://www.newegg.com/Product/Product.aspx?Item=N82E16819117649&cm_re=6800K-_-19-117-649-_-Product
I would spend all of my money on the CPU and cooling.  Water cooling would be optimal, but I wouldn't do it unless you're a pro.  I wouldn't want to mess up my expensive processor.
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786873
Hey Xanthe_2871, I don't have anything to add to the discussion as such. But I do believe you may have more luck with this question in this sub-forum https://linustechtips.com/main/forum/37-foldinghome-boinc-and-coin-mining/
There are also a few threads there with some decent info about thsi type of thing. Hope that helps :)
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786907
Thank you, that's a good idea. I'll take a look there. :)
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786969
GTX 1070 or 1060 probably. You can look at price to performance ratios from gaming benchmarks, it will work out to about the same in folding.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786972
Thanks! :D
https://linustechtips.com/topic/683919-best-wu-folding-machine/#findComment-8786997
