GeForce SLI question.
Go to solution Solved by RollinLower,
7 minutes ago, MrKat said:
These. Difference between single and dual connector.
well, on pascal the GPU's use both of the SLI fingers to increase the bandwith to communicate with eachother.
I have a question about the SLI. So the newer GPU's come with 2 SLI connectors. I cannot seem to find any topics about this. Also some bridges can only connect one connector to the other graphics card whist other bridges can connect both of the connectors on top of the graphics card. I want to ask what are the benefits of using a dual connector sli bridge against a single connector bridge. Thanks.
https://linustechtips.com/topic/683781-geforce-sli-question/
wait wut.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/683781-geforce-sli-question/#findComment-8785132
Newer 10 series graphics cards do not support SLI past 3 cards, thus why they only have 1 finger each.
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/683781-geforce-sli-question/#findComment-8785163
https://linustechtips.com/topic/683781-geforce-sli-question/#findComment-8785167
1 minute ago, RollinLower said:
well, on pascal the GPU's use both of the SLI fingers to increase the bandwith to communicat with eachother.
Aha thanks! Also does ASUS make high bandwith bridges? I saw they only have single "finger" for dual SLI. https://www.asus.com/Graphics-Cards-Accessory/ROG_Enthusiast_SLI_Bridge/
https://linustechtips.com/topic/683781-geforce-sli-question/#findComment-8785186
15 minutes ago, M.Yurizaki said:
You need the HBM bridge if you want to run 4K/5K in SLI properly. And possibly 1440p @ 144Hz (though the so-called "LED SLI Bridge" does this too)
I'm getting 208 FPS in GW2 fully maxed at 1440P :D I know off topic (and an older/not very demanding game, but I couldn't resist) 1080 might be overkill!
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/683781-geforce-sli-question/#findComment-8785274
