Need help with solving G-Sync problems
OK.
I fixed this.
ALSO THIS MAY BE GAME DEPENDENT SO IT WONT WORK 100% BUT I ONLY ENCOUNTERED ONE GAME WHERE IT DOESENT WORK AND THAT IS - Owerwatch - EVEN THEN IT DOES HELP QUITE A BIT.
Solutions:
1.) G-Sync drops your FPS to the 20-24FPS range?
Go to Control Panel - Power Management - Choose what the power buttons do menu (on the left side) - Uncheck Fast Boot then restart your PC.
2.) Your FPS are now fine but whenever you run video or some game client with animations on your other monitor when you play games in windowed or borderless mode your FPS suddenly fall down and you get a lot of stuttering?
Go to NVIDIA Control Panel - 3D Settings - Program Settings - click on ADD - Find your web browser and add it - CHANGE these settings "Preffered refresh frequency" to CONTROLED BY APPLICATION and "Monitor technology" to FIXED REFRESH RATE.
You may want to do this for every application that will cause this issue. For me changing the browser settings was enough.
This fixed stuttering in every game I tested (CS:GO, Rocket League, Dota 2) but it didnt fixed stuttering in Overwatch. However it reduced stuttering in Owerwatch by a lot and the game is completely playable in windowed or borderless mode however runing it on full screen is still better.
