Hi all I have had my s7 edge for about 6 months now but i seem to run into a problem over night one night I woke up and went to plug it in but it said there was mosture in the port i found that a bit odd as i had never put it in water but i put it in rice for 24 hours and then went to try again then  i put it in rice for another 24 hours then tried again still nothing at this point i tried drying using a hair dryer from  distance using a vacum cleaner against the port still nothing
*NOTE* i tried it with 3 different cables then bought a new one still did not work
Please help :(
CEO of Infinity Creations
No current PC but on the WAY!
https://linustechtips.com/topic/683653-s7-not-charging-please-help/
are you sure the problem is not from the power brick?
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
Please help :(
Sounds like the sensor's acting up. Just have it serviced. It must be well within it's warranty.
6 minutes ago, CaptainBlue01 said:
i cracked it so the warranty has expired
well what you can do now is bring it so an official service center
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Well, that sucks. I guess you could try a factory reset in case it's a software issue. Get your data out of there and follow these instructions: http://wccftech.com/how-to-hard-reset-galaxy-s7-and-galaxy-s7-edge/
Samsung does after-warranty service too. At least get a quote from them.
i would try what Naeaes said and factory reset it, hopefully its just a software bug rather than the physical sensor. Otherwise either take it to samsung or go third party, its possible that samsung may still repair the phone even if its cracked. My girlfriend got her sony xperia z5 premium headphone jacked repaired under warranty despite the fact that she had dropped the phone and cracked the front glass. So worth trying i guess
Tried tha still does not work :/
Okay will take it to Samsung next week
