Just now, Jed M said:
I honestly feel like just linking the Java website and YouTube.
ya, but the problem is that a lot of it is too specific, so i cant directly find the stuff. and i dont have the time to teach myself the lesson. i procrastinated on this too long lol.
You don't have the time to learn how to do your homework... yeah, you're going to go far in life.
you know the easiest way to answer some of these is to bust out eclipse and try some of them.
My observations of educational assessments:
Everything you study will not be in the test.
If you get 100% they will review your answer sheet and subtract a mark for leaving out a full stop.
In multi-choice:
 - the longest answer is always correct.
 - The answer with a word that is also in the question is correct.
 - Answers over several questions follow a repetitive pattern.
Answers to multi choice can be found in questions in the long answer section and vice versa.
ψ ︿_____︿_ψ_
In multi-choice:
Thanks for the tips!
how long have you "procrastinated" for? If you haven't haven't put any effort into learning the subject why should we do the work for you?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
About half of those questions are able to be answered by simply opening an existing project in Eclipse/IntelliJ and looking at the tooltips :)
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
