Just now, PCNoobie said:
If you turned your psu off, then it's safe to touch it, but I think it fried your components.
I just need the hard drive and the CPU, and the computer wasn't in BIOS when it exploded so the hard drive wasn't in use, could that change anything
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783222
Both are almost certainly dead.
CPU too probably.
Ram and SSDs and GPU are possibly alright.
It is safe to touch after unplugging everything.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783223
Just now, andrew.neubauer0409 said:
What the heck power supply was that!!!
It was a included one in a pre build PC, I got it as a hand me down as my dads boss, so it was heavily under use and it had a Pentium D, I think that tells how old and how used it was. I always knew it was unreliable, but I had know money to replace it.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783234
ahhhh...damn that is freaking old and props to keeping it running for that long anyway.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783238
Just now, TheCODclown25 said:
It has no SSD or GPU, and only 2GB of RAM.
Yeah...its time to scrap it and get a new comp. You can find a crap ton of budget builds online from people like austin evans and jaystwocents if you need some insperation. (if you don't already watch them)
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783246
Good point, I'm saving up for a new build anyway. But do you think I can get some money if I sell the parts for scrap metal
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783252
Depends if there is a place around you that will accept it as payable scrap...but even then a lot of places don't pay for that little of a bit or if they do it won't be a substantial amount. So all I can say on that is find out if you local recycling centers accept computer components regularly or if there are certain times they only do. I know my only does during the spring and the first part of the fall.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783255
you could tear out the copper and get a dollar. the steel in the case isn't worth anything. electronics recyclers prefer to refurbish than recycle if they can because they make almost nothing on recycling, even if there is a tiny amount of gold in each motherboard.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783272
Tearing out the copper is a great idea...wish I would have thought of that when I took mine down there. They gave me 20 something bucks for everything on my end...but I also had other scrap metal and a few bags of aluminum cans. If I can find my receipt I'll tell you what they gave me for my computer.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783286
where I am they pay 3X more if you remove all plastic insulation from copper but they next to nothing for metal that has been galvanised or mixed metals they have to seperate by hand.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783297
Found my receipt and guess what they gave me for it...$0. Oh well I took it there to make sure it didn't just get thrown in a random landfill somewhere. At least I know that most of it has been dealt with properly. So yeah people...tear the copper out of its protective covering and take it apart...cause you should actually get something for it then.
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783307
46 minutes ago, TheCODclown25 said:
HELP! My power supply exploded (literally, there was sparks and a loud bang). And I was wondering is my motherboard and hard drive still useable, (I don't think so) and is it safe to touch the MOBO to remove the hard drive
a lot of modern PSU's, and motherboards have surge redundancies for if and when PSU's malfunction or fail, so that they can sometimes not take everything with it.... but if your PSU failed so catastrophically it literally went BANG, theeeennnnn all bets are off as to what, if anything, actually survived lol. sorry m8
https://linustechtips.com/topic/683583-help-help-help/#findComment-8783316
