I decided to get back into ESO today and so I downloaded it and started playing with all settings maxed with no issues. I decided I wanted to enable Nvidia surround so I could play on all 3 monitors, so I closed the game and configured Surround. When I opened the game the frame rate is absolutely terrible. It is the exact same whether I have all the settings minimum or maxed. I also tried full screen and windowed separately with v sync both on and off. Here is the kicker...when I have another window open in front of ESO, like Firefox or windows explorer, the frame rate jumps up to 60+ FPS where it should be, even on ultra settings. The second I click ESO as the active window it dive bombs. I've tried switching v sync off and on and resizing the window in windowed and full screen modes. The only way it works is if there is another active window on top. I tried a fresh download and install on two different hard drives and that hasn't made a difference. Ideas?
i7 4790k
Gigabyte GA-H97N-WIFI
8GB of PNY 1600Mhz
Nvidia GTX 980
Corsair 250D
x2 128Gb Sandisk SSD's in RAID 0, External WD 2TB
Thermaltake 750
Corsair H100i
Razer Black Widow
Razer Mamba
Logitech 5.1
Windows 10
https://linustechtips.com/topic/683573-elder-scrolls-online-nvidia-surround-issue/
Have you tried INI edits?
Try this first.
http://www.wsgf.org/dr/elder-scrolls-online/en
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
45 minutes ago, ankybone said:
Not sure what I'm looking for here. Nothing seems to be describing my issue...
He means you can span across all displays without using Surround which may fix your issue.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
6 hours ago, Soundsystem90 said:
Just use one screen like most normal humans.
NEVER! Most games look very good in triple setups and it's a wholly different experience once you fill your periphery.
