So I've heard about the gtx 1080 FTW having issues with thermals on the VRM. I have one of those cards and i'm wondering if i should be scared, i'm not planning on overclocking my card or run benchmarks or stress tests, i use it purely for gaming at 1440p, so i don't know if i should worry about this or no. Getting thermal pads from EVGA is not an option because they don't ship to my country.
Any insight would be appreciated.
https://linustechtips.com/topic/683548-gtx-1080-issue/
Nothing to be worried about. EVGA knows what they are doing and you will certainly get a top-of-the-line GPU for your money. By the way, the GTX 1080 was made for 4K, so try to utilize its full power if you can. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/683548-gtx-1080-issue/#findComment-8782826
eh tbh 4K gaming is still iffy with a 1080, when the 1080 TI comes out then it'll be perfect.
https://linustechtips.com/topic/683548-gtx-1080-issue/#findComment-8782861
Yeah, and even if i had a 1080ti, i would still keep playing on my 1440p 144hz gsync monitor, it's just WAY better than a 4k/60hz monitor.
I just hope my card doesn't fry :L
https://linustechtips.com/topic/683548-gtx-1080-issue/#findComment-8782873
EVGA is handing out some thermal pads for free, IIRC. It'd be worth asking for them just for the sake of having them.
Luckily, I have thermal pads of various thicknesses in the server room so I just did it to be safe... and b/c I like taking things apart.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/683548-gtx-1080-issue/#findComment-8782908
