Monitor Help?
Xreldo
Go to solution Solved by Xreldo,
Ended ill just look myself
I was wondering if there is a monitor at around £100 that is 1080p and has over 60hzs? Please suggest.
60ghzs? that's a lot dude
I'm unable to find one over 60hz for £100.
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
I mean 60hzs
Just now, Xreldo said:
thats the minumum a monitor has..
1) No its not.
2) Its Hz. Not Ghz.
Just now, SherifsDog22 said:
1) No its not.
2) Its Hz. Not Ghz.
I didnt say ghzs ;)
6 minutes ago, Xreldo said:
I was wondering if there is a monitor at around £100 that is 1080p and has over 60ghzs? Please suggest.
Something like this,
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824160170
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824025402
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
1 minute ago, Xreldo said:
I didnt say ghzs ;)
Good job changing it ;)
1 minute ago, L.E.D said:
This is at 60hz
