best monitor setup under 500 (dual monitor pls)
aries757,
To be totally honest, if you have a budget of $500, you can do quite a lot for a dual monitor setup. I'll put a few suggestions down below of some compatible setups you can do. I will try to find the best prices for you or have a PCPartPicker link with all of the products so you can save the most money you can. All included monitors are VESA compatible and will work for their respectable mounts as far as dimensions go. Also, if you could provide me with a spec list of your current system, I could more easily assist you with your question.
Dual 21:9 Ultrawide Setup (My personal favorite option for you) - $487.99 (excluding tax and shipping)
2 LG 25UM58-P 25.0" 75Hz Ultrawide Monitors
Amazing ultrawide monitors, cannot understate the happiness they have brought me over the past 2 years I have personally owned them!
https://pcpartpicker.com/product/wNcMnQ/lg-monitor-25um58p
Mount-It! MI-7C24
A sturdy piece of equipment that does the job it is tasked to do.
https://www.amazon.com/Mount-Monitor-Height-Adjustable-Motion/dp/B00B3YQG4Q
Dual 16:9 Asus Setup - $261.77 (excluding tax and shipping)
Asus VS228T-P 21.5" 60Hz Monitor
A glorious screen that has good contrast and decent image quality. It's no high detail graphic designer's monitor, but it pulls through with a very respectable pricetag.
https://pcpartpicker.com/product/tkL7YJ/asus-monitor-vs228tp
Planar Dual Monitor Stand
Like the last one, it is a sturdy piece of metal with one job: to hold up monitors.
https://www.amazon.com/dp/B0013TZRUA?tag=dabestrevie0f-20
Hope you find these helpful. If you could provide me with your specs I can help your further.
Best regards and may the glorious PC master race prosper,
American Mongoose
