TRIPLE 28 INCH 4K MONITORS VS ONE 43INCH 4K
billetblock
Hey guys just built a new midrange budget rig with sapphire rx 480 8gb OC all for about 500 dollars
I found upstar  28 inch monitors for 99 each they are tn panels
I just purchased an lg 43 inchIPS4KTVthat supports chroma 4:4:4 4k 60hz for 299
Has anyone used those upstar 28 inch 4k monitors? Do you guys recommend taking back the 43 inch 4k LG tv and buying the 3 28inch 4k monitors instead?
The room is very very small where this workstation is hence my concern for 3 monitor setup
this is mainly used as a workstation for multi platform trading with gaming as secondary
your help is much appreciated
3 monitors makes for splitting up open tabs on the internet (I assume platform trading is online) easier, and as you dont sound too bothered about quality then TN is fine.
Ive heard bad reviews about these upstar 4k 28inch monitors i really want to take back the tv and buy these but then i have to spend more  about 150 for stand for them too. Has anyone had experience with these monitors http://www.kmart.com/upstar-28inch-4k-uhd-led-monitor/p-012W008507308001P?sid=KDx01192011x000001&gclid=CI7a0dTZgNACFQYGaQodkmAA7w&gclsrc=aw.ds
anyone recommend any stand for triple 28inch monitors?
Are these monitors any good?
