Currently I use Thermaltake Riing fans for my radiator and while they get the job done ok and look quite nice I was wondering if anyone knew of any better LED fans out there specifically 120mm and 140mm ones for Cases and radiators.  I haven't had much luck in searching around and it seems that Thermaltake is one of the only brands that makes LED fans at least from what I've come across.  I've also seen some slim pickings from Corsair.
Thanks.
https://linustechtips.com/topic/682378-led-fan-recommendations/
Thanks.
wut led color
MF UH BEANS
https://linustechtips.com/topic/682378-led-fan-recommendations/#findComment-8772471
Aerocool DS. Very quiet, looks awesome, moves a ton of air. Downsides are that they tend to be pricey and they are not PWM. That's never stopped me from using them.
I've read good things about the Corsair ML LED fans, but their previous AF and SP LED fans were expensive bat crap.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/682378-led-fan-recommendations/#findComment-8772486
Corsair's LED SP fans are pretty much the best LED fans.other than I'd say no to LED's and just get GOOD fans.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/682378-led-fan-recommendations/#findComment-8772512
No, they're not. They're okay at best.
Gelids Wings, Dual-X's, and Aerocool DS are easily better.
https://linustechtips.com/topic/682378-led-fan-recommendations/#findComment-8774810
On 10/28/2016 at 11:25 PM, ELSknutson said:
Personally Getting something Like the HUE plus looks allot better then LED fans. But Corsairs new LED fans look pretty good
Thanks everyone for your input.  I have a better idea now where else to look and choose from.  I'm leaning towards the Aerocool ones and seeing their options for radiators as I plan to upgrade to a H115i so i'll check out their 140mm offerings get two for the rad and a separate case fan for my exhaust to replace the stock fan I have now.  Thanks again everyone.
https://linustechtips.com/topic/682378-led-fan-recommendations/#findComment-8780153
