My friend's 60fps looks better than mine on a 144hz?
TheSuspect
I have an Asus VG248qe, and my friend has a Samsung S24d300h. So, whenever I set my monitor to 60hz, and spin around in cs go quickly, it doesn't look as smooth/fluent as my friend's display. (1080p60fps). We're both getting far above 60fps and we're both using Nvidia drivers (latest). I'm using DualLink Dvi, my friend is using Hdmi. Ideas?
(And nothing above the human eye not seeing above 24/60 or whatever fps, please.)
Nothing.
 it can be ambient lighting, you should just try switching monitors to see if the problem presists. for example, led lights flash at 50hz or 60hz depending on your power grid, that can create the illusion that its 50 or 60hz. other than that i wouldn't know.
My 165hz asus is the same. Set it to 60hz and its litteraly eye cancer compared to my old 60hz monitor. No idea why.
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
10 hours ago, Gonio said:
Certain video settings maybe. Has he got Vsync on and you off?
We both don't have Vsync enabled
We'll try that.
Nothing.
