Help!! recover formatted drive
21 minutes ago, Voltz said:Can you guys help me recover my formatted drive? i wasnt suppose to format that drive and i had lots of family photos on that drive... Please Help
Don't try recovering the partition table just yet. Get the files themselves. Whatever you do, don't write onto the drive.
So what you need is a second drive that you can save the recovered files onto. Then a program that can read the data off of the formatted drive.
Piriform recuva is one decent and free software: https://www.piriform.com/recuva
I've had loads more luck with Photorec http://www.cgsecurity.org/wiki/PhotoRec It's not as easy to use though. But it's also free.
The best I've come across is EaseUS data recovery, but that's paid http://www.easeus.com
EaseUS can get you your filenames and folder structure too. The other two just get the files with on-the-go-generated names and dump them all in a single heap. They do retain the metadata though, so you can then rearrange the photos according to something like date taken. I'd suggest starting with Recuva, then re-doing the scan with Photorec. That's how I usually go about this.
