Hey guys im 12 im looking to upgrade my pc on a budget (dont judge i have a shity setup) so the setup i am using now is:
Asus maxmus II Formula
6gb ddr2 ram
2.3 grh qaud core cpu
hard drive
500w power supply
high end sound card
geforce gtx 580
so should i upgrade graphics card ram hard drive or what???????????????????????????????????????????????????
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/
4gb ddr2 ram
hard drive
500w power supply
high end sound card
1) do you even have a GPU yet?
2) That CPU is OK not good but OK, it wil run CS:GO but not GTA 5
3) Get 8GB DDR2 Ram and if you want a GPU get a Nvidia GTX750 ti or a 650 ti Boost!
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8757700
21 minutes ago, LukeO0805 said:
i have a gtx 580 BRAH I BUILT THIS COMPUTER ON A $200 BUDGET NO TITAN XS HERE
So you ant to spend 200 on an upgrade? Well first and foremost, get a new gpu. I recommend a 1050ti or a rx470. The 470 will perform much better for 50$ more, so if you can afford it, it's worth it. Besides that, I wouldn't really change anything. Your system will run every game acceptably, and your next upgrade should just be a full system replacement.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8757756
would suggest a 2nd-3rd gen i5, cheap mobo and 8gb of ddr3 for your next upgrade. then move to an rx 470/480/gtx 1060.
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8758280
He also only has $200, if you can squeeze that for $200 you're likely a god
"Better to be bad at video games than mad at video games" - BadAtVideogamesMan
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8759945
If he could, just sell and upgrade maybe, wouldn't sell the whole system, and even $300 would get him a lot further than $200
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8759952
Unfortunately, the most meaningful upgrade you could do would involve a new CPU, RAM, and motherboard. Plus, of course, you may need a new OS. Also, the new CPU would need to be better than your current one, so that may leave out the very cheapest options.
I'd look into an i3-6100 with an H110 motherboard and at least 4Gigs of DDR4 RAM. Price that out and save towards it.
Another option would be an AMD FX-6300 with appropriate motherboard and DDR3 RAM.
Look around for good used units.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/681048-200-doller-upgrade-guide/#findComment-8759990
