I'm thinking of building a mini ITX build but, I'm not sure if everything will fit. Based off the dimensions everything should come together properly. I was just curious if anyone has attempted a build like this and has any input they can give me. Also with the graphics card and water cooler taking up so much space, how many drive bays would I have left?
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($442.98 @ DirectCanada)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: ASRock Fatal1ty Z170 Gaming-ITX/ac Mini ITX LGA1151 Motherboard  ($245.00 @ Vuugo)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($109.99 @ Newegg Canada)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($936.50 @ Vuugo)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case  ($114.99 @ Newegg Canada)
Power Supply: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($194.98 @ Amazon Canada)
Total: $2044.44
Generated by PCPartPicker 2016-10-25 23:35 EDT-0400
The BitFenix Prodigy (Black) Mini ITX Tower Case supports video cards up to 317mm long, but video cards over 177mm may block drive bays. Since the Asus GeForce GTX 1080 8GB STRIX Video Card is 298mm long, some drive bays may not be usable. Unable to verify the BitFenix Prodigy (Black) Mini ITX Tower Case has sufficient mounting depth to support the Corsair H100i 77.0 CFM Liquid CPU Cooler 240mm radiator.
https://linustechtips.com/topic/681031-build-ready-possible-space-issues/
If PC part picker says yes then it most likely will fit.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Yep, your good. Pcpartpicker will flag space issues.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
7 minutes ago, KyleBurns said:
Whats the overall differences besides the one you linked only having 2 SATA cables ?
a better power components, also it has more than 2 sata ports
Edited by GDRRiley
pcpartpicker does not pick up every compatibility issue. It is particularly weak when it comes to cases a cpu coolers. In this case however, it notes that the external drive bay has to be removed to mount an H100. See http://www.legitreviews.com/bitfenix-prodigy-mini-itx-case-review_1986/5 for a picture.
You need to remove the optical drive bay for the AIO to fit.
http://www.tweaktown.com/tweakipedia/1/bitfenix-prodigy-tweaktown-pc-build-guide-part-1/index.html
1_12_needs_images_bitfenix_prodigy_tweak
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
