This is the system I am getting or most of it alteast (no GPUs yet, but I will CF or SLI)
http://pcpartpicker.com/list/sNg38K The prices are adjusted to danish pricing.
What would be a good case, please keep it under 150$
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/680764-case-for-this-system/
Get a Coolermaster Mastercase Pro 5
If you still have enough budget afterwards, you can maybe buy the tempered glass side panel
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754486
I'm a huge fan of Phanteks, and recommend the Enthoo Pro wholeheartedly.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754489
Didnt you want to go mATX m8?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754500
yeah, but the boards are very meh at best and there are just something that I want to do that I cannot do. Like CF + Firepro and mimo wifi
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754505
does not support E-ATX
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754511
Why the f*ck do you want a firepro? lol.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754516
Because they are cheap in Denmark apparantly and you know 3D work and the smexy blue color and because I can. It is a very strong maybe. Also even with the mimo wifi it would not fit onto a mATX board, unless you find one that is perfectly slotted, but even then you would sandwich the cards together and then the fans would go up, then I would be annoyed, because open headphones and then lastly I would get mad at some point.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754551
Don't get a firepro m8, even if they are cheap.
As for noise, you'd probably want watercooling anyways because dual cards no matter what brand, will get toasty and loud.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754570
it seems a bit iffy E-ATX *(up to 264mm wide), I have no idea how wide that Asrock board is
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754573
well with that asrock board it has two slots between GPUs natively, that is a hell of a lot better than one or none. Watercooling is so expensive, I am not made out of money
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754589
I can confirm the shit-load of room in that case.
Solitaire.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754619
seems a bit on the small side still. Any other options?
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754688
NZXT H440, Phanteks enthoo Primo...
Just go to PCPP and look at compatible full towers.
Solitaire.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754697
the Phanteks Enthoo Luxe seems nice
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754783
It's a good case, though I went with the Pro because I have a NZXT Hue Plus
Solitaire.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754792
the tempered glass version looks nice. Looks like I can do push pull in the top. It also has RBG around the edge, not the biggest fan of RBG, but I guess that it could look nice.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754810
You can always turn it off.
Solitaire.
https://linustechtips.com/topic/680764-case-for-this-system/#findComment-8754812
