Hey guys, I'm not sure if this is the right place to post this but here goes :
I accidentally clicked on a phishing email link which claims its from Apple. The link directed me to Youtube.
How would I know if this has downloaded something on my PC ?
Thanks in advance.
https://linustechtips.com/topic/680722-phishing-help/
For your peace of mind, you can run Malwarebytes to look for suspicious items, and pretty much any antivirus company lets you download a trial of their products that works for 1 month.  I recommend Kaspersky antivirus.
Mystery is the source of all true science.
https://linustechtips.com/topic/680722-phishing-help/#findComment-8754144
25 minutes ago, Lehti said:
Browsers are sandboxed, you're probably fine. And if you didn't do something really stupid (like disabling UAC, for example) programs cannot run without your permission.
I didn't disable it.
I've run Malwarebytes already and it shows there's nothing. I have Norton 360 in my PC which I've used to do a quick scan and nothing has been detected.
https://linustechtips.com/topic/680722-phishing-help/#findComment-8754204
