Hi, I'm building my first PC soon, and I wan't to know if these will work together. I know there is PC part picker but I've heard it can mess up,
CPU -
Intel i5 6500 - $205
Graphics card -
GeForce GTX 1060 - $200
RAM -
8 GB (4GB x2?)- $40
Case -
$30-$50
Motherboard -
Gigabyte LGA1151 Intel H170 Micro ATX DDR4 Motherboard (GA-H170M-D3H) - $90
PSU -
Rosewill 80 PLUS BRONZE Certified Power Supply ATX12V / EPS12V 550 Power Supply Hive-550 - $55
Memory -
1 TB HDD  (WD Caviar Blue)- $50
Toshiba OCZ Trion 150 120GB 2.5" 7mm SATA III Internal Solid State Drive TRN150-25SAT3-120G - $40
Also does anyone have a recommendation on what RAM and case I should get?
Thanks and have a nice day!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/679929-i-need-help-building-a-pc/
WRONG THING SORRY PLEASE DONT REPLY
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
CPU -
Graphics card -
RAM -
8 GB (4GB x2?)- $40
Case -
$30-$50
Motherboard -
PSU -
Memory -
build seems fine i would see if you can upgrade to 16gb of memory for better preformance.  in terms of memory and the case thats up to you
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
5 minutes ago, PCNoobie said:
I accidentally copied and pasted the wrong thing, I just posted a new once with the right things
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
