Does anyone know how userbench works when it compares your data from your benchmark to others?
It says I'm in the 78th percentile, and says out of 100 PC's with the same components, 23 performed better.   Do they base that off all system data added together?  I can't imagine 23 out of 100 systems are running the same clock speeds I'm running, so it must be something else, like SSD + CPU + GPU + OS + Memory or something?
http://www.userbenchmark.com/UserRun/1920878
https://linustechtips.com/topic/679600-userbench-how-does-it-work/
Just now, dexxterlab97 said:
Aww ok, if I had an M.2 SSD I'd be at the top probably then, makes sense I guess lol
3 minutes ago, Katsunaka said:
Probably just saying that with each individual part. Not the whole system.
Did delidding help much? My 6700k is 5ghz capable. I just turned it down to 4.8 after I went ITX.
I'd love to see a Cinebench Screenshot! What voltage are you running for 5Ghz?
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
It's not running 5 anymore. I did it when it was ATX, now it's ITX.
I was running 1.39V in the bios to get there. Now that it's in an ITX board, the hardest thing its seen is getting powered off when my dog stepped on the red switch for the surge protector.
1.39v for a CPU-Z or Stable? Most 6700Ks are Delid + Custom and 1.45v for 5Ghz stable...
1.39V is what I put in the bios for voltage, and it was stable. Not delidded, no custom loop, nothing special. Just kept creeping up on voltage and multiplier to get there. Once it got there, it stayed there.
30ish idle, 60-65 gaming 80 ish under a benchmark load.
