Hello,
Tuesday I was given 2 Laptops, a HP Probook 4310S and a Probook 4710S.
They were both running Windows XP, so yesterday I installed 10 on them.
After I had finished installing windows 10, the Probook 4310s now displays to "13% not charging" when the computer is plugged in, the charging LED on the laptop itself also isn't on anymore,
I have tried 3 different Chargers (3.33A HP, 3.34A Dell, 3.5A HP from the laptop, 4.74A no name) and it is still not charging.
Any ideas?
https://linustechtips.com/topic/679568-laptop-not-charging/
Just now, Hydrogen1803 said:
I'd check in the laptop internally, especially if the charging port had ever received stress such as a charging cable pulling on it for long periods of time. This happened on an old laptop of mine and something was wrong with the charging mechanism.
The computer stays on when the power is plugged in, so I don't think the charging port is bad.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741454
It could be a bad battery, considering it stays on but does not charge up. Maybe even something with the drivers, so I'd check those as a precaution.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741474
The thing is the battery was charging fine and holding charge fine a couple of days ago. I was moving across the files that the previous owner left on them and I wasn't plugged in.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741484
my phone got dropped and keeps on reporting false battery percentages, even when charging, i've just gotten used to counting the use time of my phone instead of the actual percentage, that might be the issue - the software that's managing the battery
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741500
This definitely could be.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741502
I unplugged it, it went died after 10 minutes or so. It isn't a faulty counter.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741543
25 minutes ago, Comic_Sans_MS said:
Hello,
Any ideas?
Might either be a battery, or battery charging circuit issue. If you can try with a different battery and confirm it doesn't work, that means the problem is in the circuit.
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8741586
3 hours ago, Comic_Sans_MS said:
The problem with that is that the laptop is 7 years old, I don't think HP would support it.
If you've gotten a laptop battery to last longer than about 4 years you're already riding on free time.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8742218
It is a Probook, it is meant to last.
The battery hasn't slowly decayed away, it is just not charging at all.
https://linustechtips.com/topic/679568-laptop-not-charging/#findComment-8742242
