So this is first time i do a pc build, i have found the things i think is importent but i really want to hear your opinion. i want to build it with a i5-3570k and a gtx 670 as main komponents.
http://www.komplett.dk/k/shoplist.aspx?mode=receive&si=1207308&su=A45B0D1D-E1D1-4777-AAF9-A9D4BA02754C
Hope you can help
https://linustechtips.com/topic/6789-nedd-advice-on-first-build/
i would change a few things here and there.
firstly the psu, change it to something between 600w to 750w,
for the storage drive, i will atleast look for 1tb these days.
and i am not sure about the thermal paste, maybe the h100i will already have the paste applied to it? someone else could point this out would be great
all the rest are good i suppose
https://linustechtips.com/topic/6789-nedd-advice-on-first-build/#findComment-72989
Yes, 750W is enough for SLI, as long as you're not running two dual-GPU video cards.
For such an impressive build, I would consider a better SSD. You should get a high performance one. Anything from the 840 Pro, to the Vector, the M5 Pro or the Neutron GTX is a more consistent choice.
Quality thermal compound is indeed pre-applied on the H100i.
https://linustechtips.com/topic/6789-nedd-advice-on-first-build/#findComment-73026
yup, that should be enough, and as for the noctua thermal paste, dont buy it, as crowcore mentioned tthat the h100i will have the thermal paste applied already, so you can save some bucks, why not buy some extra fans for cooling, and buying a pack of cable ties for cable management?
https://linustechtips.com/topic/6789-nedd-advice-on-first-build/#findComment-73031
Like "razersum" said, you won't need to buy any thermal paste as the thermal paste pre-applied on the H100i is already quite high grade.
750W is more than enough to have SLI, and enough for triple SLI.
Everything else looks just about perfect... But why that keyboard D:
https://linustechtips.com/topic/6789-nedd-advice-on-first-build/#findComment-73097
