Alright, I just installed my graphics card (correctly, I hope) and I ran the driver install for it, so I thought I would be ready to start gaming. However, none of my games are starting. All Steam games 'stop working' as soon as I start them, and WoT in particular tells me ít failed to start because 'no appropriate hardware acceleration was available or was turned off'.
This is stressful, I don't know what the problem is. Can someone please help me?
https://linustechtips.com/topic/678694-help-no-games-are-working/
Either to go AMD's driver site or Nvidia's driver site and download the latest driver for you gpu and make sure to restart after installing it. Also make sure your OS is updated as well. Also make sure your monitor is plugged into the gpu, not the ports on the motherboard.
The World R:Craft - Where Dot Hack Meets Minecraft
More Info at http://forums.cyberconnects2.com/index.php#the-world-r-craft.24
Restarting fixed it. Thanks for the help!
Did you installed your GPU while your PC was ON?
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
4 minutes ago, Snappy said:
Of course not! I may not be great at software, but I have common sense. Right now, it only seems to be my Dark Souls 2 that crashes, so it's not the graphics card's fault
Which Server do you play WoT?
I've only got a couple tanks. :( Russian TDs, One American one T67. Highest tier is 7. SU-152
I play on the Asia server. There's no dedicated server for Australia yet, so I play with around 150 ms :(
:( That's really bad.
1 hour ago, Snappy said:
Yeah, but it's the best I'll get until they give Australia and NZ a dedicated server
Do you know when they will set it up?
