PWM Fans always running at full speed
Solved by LogicalDrm,
18 minutes ago, RISKY_BUSINESS said:Im using the system fan header. I guess i just assumed that it would work since the header has four pins. I will try the CPU header when i get home and i will give an update. Thanks!
That will solve the issue. If you look at manual how pins are connected, it says VCC for 4th pin. Thats Gigabytes way of saying it doesn't do anything special. MSI is more direct with 4th pin reading "Not connected".
As for pre-profiles. If you plan to use them, Silent will kill power to CPU_OPT unless system is under stress. So if you are using that header, use Normal or Manual mode.
