Hey guys,
I have 4 3 pin fans in my pc, and they are all plugged into 4 pin connectors on my MOBO. Since they have no PWM, they are running full speed, and are very loud. I was thinking if i switched out my motherboard for  the Asrock extreme3 r2.0, which has 3 pin fan connectors.  I think that three pin fans in three pin connectors whould allow me to control the fans via bios.
Its either this or I buy a fan controller.
If I get any responses ( i doubt it ), please correct me since im a PC noob ( Ive only built one)
Thanks
-E
https://linustechtips.com/topic/678065-3-pin-fans/
welcome to the Linus Tech Tips forums!
what motherboard are you using to control the fans with?
as per the manual: http://asrock.pc.cdn.bitgravity.com/Manual/970 Extreme3 R2.0.pdf
you'll control the fan through the HHEM screen:
https://linustechtips.com/topic/678065-3-pin-fans/#findComment-8725918
Dude....
Quote
https://linustechtips.com/topic/678065-3-pin-fans/#findComment-8725921
3 minutes ago, airdeano said:
@Enderman voom.. right over it.. thanks!
lmao xD
https://linustechtips.com/topic/678065-3-pin-fans/#findComment-8725937
9 minutes ago, ecp0903 said:
Hey guys,
Thanks
-E
Personally, I would buy a fan controller (NZXT, Phanteks).
Their cheap and the NZXT one has great software for windows.
And the phanteks one is controlled by one single 4 pin with Pwm.
May the force be with you - Yoda
https://linustechtips.com/topic/678065-3-pin-fans/#findComment-8725943
Which mobo you have now? You can control 3pin fans, even when they are connected to PWM supported connectors if your mobo supports DC controlling. Its quite a big jump to change mobo just because you have issues with fan headers.
Hub you linked works also, it will use CPU fan header as controlling unit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/678065-3-pin-fans/#findComment-8727957
