Hey guys, more issues it seems.
So I've recently put (most of) my PC together (all that's left out is the graphics card) and I'm installing Windows 7 on it.
Or so I THOUGHT.
So I watched the NCIX Tech Tips video walkthrough on how to install Windows 7 through a bootable USB drive. And I followed the video instructions to the PIXEL. And then I went into my UEFI panel and set its boot order as primary, so my PC recognised the USB drive. But whenever I get through to the panel where I select the drive I want to install from, the drive is nowhere to be seen and I'm clueless as to why.
Can someone please give me a hand with this?
https://linustechtips.com/topic/677772-issues-installing-os/
Did you leave all other options in BIOS in factory configuration? More importantly leave fast boot disabled at very least for now, preferably for good.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722593
I would also like to mention that I didn't change anything that I knew was going to screw my system up or anything. I enabled XMP, changed boot drive priority etc
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722612
Could be that the motherboard recognizes the drive in BIOS, but not as a bootable drive. I'm not familiar with that video, but what usb media creation tool did you use? I know rufus 2.0 has worked for me without fail when working with .iso OS files.
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722621
19 minutes ago, Snappy said:
I just followed this NCIX video:
That is really old video and there are easier ways to create bootable USB. Microsoft has their own tool, https://www.microsoft.com/en-us/software-download/windows7 or you can use universal tool like Rufus if you already have .ISO (or don't want to use MS one) https://rufus.akeo.ie/
Newer video how-to:
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722689
  Hide contents
I know the video says Windows 8.1, but does it work for Windows 7 also? And I'm normally pretty crap at software, that's why I thought the NCIX step by step video would have worked.
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722715
2 minutes ago, Snappy said:
If you watch video, Linus says Win7. Plus first link I put there was for Win7. Both tools work for all Windows versions. You just need .ISO.
https://linustechtips.com/topic/677772-issues-installing-os/#findComment-8722726
