I am planning to build a pc within the next 3 months after the new chips come out. But i would really like to play Battlefield 1 and Watch dogs right now. I know it might seem inpatient but i am running a gtx 650 so i cant really run the game.
Should i wait or buy a graphics card now. What cheep graphics card would you recommend?
MINIMUM SPECS
  • OS: 64-bit Windows 7, Windows 8.1 and Windows 10.
  • Processor (AMD): AMD FX-6350.
  • Processor (Intel): Core i5 6600K.
  • Memory: 8GB RAM.
  • Graphics card (AMD): AMD Radeon™ HD 7850 2GB.
  • Graphics card (NVIDIA): nVidia GeForce® GTX 660 2GB.
  • DirectX: 11.0 Compatible video card or equivalent.
https://linustechtips.com/topic/677372-help/
You can still play with your 650 but you just need to lower your settings, no need to waste money on a mediocre card right now if you're planning to buy a better one so soon.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/677372-help/#findComment-8717714
I asume you talk about kaby and Zen?
You can always buy the GPU you want and expect you need for your build. Sure it will probably be bottlenecked but that doesn't mean it gets unplayable. Imo the whole bottlenecking stuff is a bit out of context and people scream to hard that they have a giant problem.
It will play: Yes
It will play smooth enough: Yes
Will my GPU run full potential: No
Does that matter: No not really, you have to start soemwhere with upgrading.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/677372-help/#findComment-8717743
