System has been working fine for the past month and a half after build, had it unplugged from the mains for a few days and psu completely switched off, and now it won't boot?
as in nothing happens when I press the power button on the case or the start button on the mobo :/
anyone got any ideas?
im on a hero viii board, i7-6700k
https://linustechtips.com/topic/677115-system-wont-post/
4 minutes ago, wrathoftheturkey said:
Have you checked to see if everything is plugged in and all switches turned on (yes some people don't actually check before they ask)
Unfortunately I have haha
althkugh I have just noticed that my gpu lights aren't on, can't remember if they turn on when just connected to the psu or if the system has to be on though?? It's a gtx 1080 superclocked
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8714928
1 minute ago, RMP23 said:
funnily enough the exact same thing is happening to me as well, with a similar setup to yours... :/ for me when I press the power button a red LED turns on the motherboard, which apparently means that it doesn't get power; i think it's going to be a psu issue
It better not be, I just had the bugger replaced!!
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8714932
Are you on the right voltage setting for your psu? Some people switch it to (for example) 230v when they are supposed to be on 110v. This (I think anyways) can fry your psu, and maybe even your system.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8714990
10 minutes ago, Craigathorn said:
Same plug as always bud, lights on the mobo are flashing away just as they should but nothing happens when I push the start button
You didn't mention the lights in your original post. So if the lights on the mobo light up then the PS is "working" at least somewhat.
I'd try disconnecting everything except one stick of ram and use the onboard video if you have some.
Sometimes it's quicker and easier to start from the bottom and work your way up to bigger problems.
Personally I'd test the power supply by disconnecting it from the mobo and jumping the green wire on the 24pin to one of the black wires. If it doesn't turn on, some power supplies also need a bit of a load so I'd put a power resistor between one of the red wires and black wires. (All red wires coming from the PS are 5V, all yellow are 12V and all black are ground.) Alternatively you could keep a HDD hooked up.. but I've never tried that. I'll have to try it when I get home.
If the PS still doesn't turn on, then it's bad. (Basically watch the fan to see if it turns on or not.) Or measure the voltage with a DMM, but most people don't have that.
My evga power supply came with a "jumper" cable. It basically is a 24 pin female connector with the green wire jumped to one of the black wires. Very useful for testing power supplies.
EDIT: Don't leave the power supply on for long in this state, especially if you had to use a power resistor. That resistor will likely get (very) hot, so you don't want it to catch fire.
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715018
... how do you switch it between one and the other??
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715062
On most psus there is a switch (its usually red) next to the plug for you power cord
SPECS:
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715067
i've taken out all of the ram apart from 1 stick, havent taken out all the hdd's so i'll do that now
don't have any of the equipment you have mentioned to test the psu however my dad probably does so i may have to try that tomorrow
just tried plugging it in to a different plug socket and no change
would it make a difference if i disconnected any of the headers for the case??
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715071
1 minute ago, Craigathorn said:
Can't see anything here? It's a corsair rm850x
would that jut be a feature on US models as I'm in the UK.. :/
Shouldve told you it is only on some psus...yours doesnt appear to have one :/
SPECS:
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715096
That's ok haha, in other news.. just pushed the little red button next to the start and reset switch and the system powered on with nothing plugged in
had to turn it off as the cpu pump wouldn't be running but hopefully this may have fixed it
no idea what that button is though??
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715112
6 minutes ago, corrado33 said:
No it's not bad. However, all of your bios settings have been returned to stock.
lucky for me i saved my bios settings to a profile so i just had to load it back through, phewwwwwww
back to playing gears of war 4 i go haha, thanks a lot boys :)
https://linustechtips.com/topic/677115-system-wont-post/#findComment-8715262
