I have an FX-8350, R9 380 and 16GB of DDR3, im rendering in AVCHD, highest settings possible, have read up on absolutely everything to do with rendering, and this is the video I get. Anyone know any ideas on how to fix it? My video is super low quality, like 640 x 480, stretched to 1080p, and there is screen tearing, color problems, and half the video is just green . Its so bad that i'd probably get a better result if I were to screen record the preview. (Its only a 30mb download btw)
And dont ask about what the video is, ill simply ignore it.
https://www.mediafire.com/#b7juccf9505hh
(Download the .m2ts and .m2ts.sfl, and put them in the same folder)
Ryzen 5 1600 - GTX 980 Ti - Broke.
https://linustechtips.com/topic/675996-major-render-problem-vegas-pro-10/
1 minute ago, Dan Castellaneta said:
could I get some screenshots, can't really download a video rn
https://gyazo.com/f3111d7be824a2c05b8a0a79e1349597
https://gyazo.com/65fedb84ade4c2a6532604388122a69d
Just now, refinedskillz said:
Try rendering in MP4 rather than AVCHD?
It worked, but there was an error when opening file, just fixed that error, so thanks!
just like @Dan Castellaneta said, an other output container might do the trick. AVCHD is for camcorder recordings. something like MP4 will probably solve it.
edit:
seems like it has already been solved.
May the light have your back and your ISO low.
Ah, no problem man.
