4 minutes ago, D148xZ said:
I recently built this pc, I practically got everything used and it's working great.
https://pcpartpicker.com/user/D148xZ/saved/r32999
Do you think I got good deals on the parts? And should I change out some things?
Pretty lit. When you get a chance, also get a hard drive to go with it.
i like trains 🙂
https://linustechtips.com/topic/675981-i-built-a-pc/#findComment-8702749
Not bad, just needs a case :)
I would also recommend getting a larger ssd or second storage drive.
But for $200 that a nice pc :)
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/675981-i-built-a-pc/#findComment-8702784
I already have a case, kind of. I have a power Mac G5 lying around and I'm planning in making it into a case. I'll get around to it someday.
https://linustechtips.com/topic/675981-i-built-a-pc/#findComment-8702790
Probably look for another $10 1600Mhz 4gb ram to replace the 1333.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/675981-i-built-a-pc/#findComment-8703979
