alrigtht, so i recently got my EVGA GTX 750ti sc and i've been having some problems. the resolution, it wasn't adjusting  to my monitors screen resolution which was kind of an annoyance but i changed it to 1176x664. When i launch a game it seems that nothing is wrong as it goes to the resolution i set it as, on my desktop however......THE RESOLUTION IS TOO BIG. the top sides and bottom are cut but half, and the black borders are no longer there. on my cpu side, everything is fine as i can go up to 1366x768 res. but this, any resolution is wrong and doesnt fit. my "monitor" as one could say is an emerson LC190EM1 19"  disgusting i know, upgrading to a better 24 in monitor soon. if you all could kindly help me with this problem
https://linustechtips.com/topic/674590-resolution-help/
Go to your Nvidia Control Panel:
  • Display > Adjust Desktop Size and Position
    Under Scalling, Select Auto Aspect to see if it auto adjust.
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
https://linustechtips.com/topic/674590-resolution-help/#findComment-8687742
There isn't an option for the auto aspect, the scaling mods that are there is aspect ratio, full screen and no scaling.
https://linustechtips.com/topic/674590-resolution-help/#findComment-8692310
https://linustechtips.com/topic/674590-resolution-help/#findComment-8692451
21 hours ago, Waqas409 said:
-snip-
well, you said auto aspect so i got confused. it was always like that. and it seemed to never auto adjust. i fixed the 1176x664 though. it was on cpu and i changed it to gpu and some other things around. still cant get it to fit properly though
https://linustechtips.com/topic/674590-resolution-help/#findComment-8696772
