My setup for media is my freenas system that i use to stream to my media pc running xbmc in ubuntu. i am having some problems that i was hoping someone could help me with.
1.after updating the media pc i can not get it to log into the nas it just keeps making me do it over and over again.
2. I have a problem on the media pc which is most likely my fault entirly but i installed ubuntu from a flash drive and i9t now only uses 4 gb of data. I am trying to add a free partition to it so it has 74gb of space but it will not let me do so because another partition is in use.
3. Lastly im having trouble ripping the dvds that i own with handbrake. I get really long files filled with audio or i get the movie with large sections chopped up and unplayable
Any help would be appreciated
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/67427-help-please/
I fixed the problem of it not loging in but i still need some help with my other 2 problems
I also set up my grandmothers old lg smartphone as my new remote for xbmc. she just got an iphone 5c
https://linustechtips.com/topic/67427-help-please/#findComment-923045
I'm not sure but you're probably better off posting this in the Software section: https://linustechtips.com/main/forum/10-operating-systems-and-software/
https://linustechtips.com/topic/67427-help-please/#findComment-923467
so should I repost? the only problem i have now is ripping dvds that I own
https://linustechtips.com/topic/67427-help-please/#findComment-923539
Either report the post to a mod to get moved or make a new one.
https://linustechtips.com/topic/67427-help-please/#findComment-923586
