I want to use as intake an old 3pin 92mm fan from a €10 Pentium 4 CPU Cooler that has never been used, since I ran out of fan headers on my mobo and my other fans are 4pin, there is a €2 3 pin to molex connector on amazon.it, but I'm worried that the fan will be way too loud at full speed, I have the low noise adapters from an NH-L12 but they probably won't work, since they're 4pin and AFAIK 4pin is PWM and 3pin is DC, so that's not what I'm looking for
APU: AMD A10-7850K cooled by an NH-L12; PSU(going to upgrade sooner or later):  Antec VP450P;RAM: 2x4GB HyperX Savage 2133MHz; MOBO: Asus A68HM-Plus; CASE: Itek [something] ; HDD: WD Blue 1TB(WD10EZEX)
OS: Triple boot openSUSE Leap Debian Jessie and Windows 10(aka MSX)
https://linustechtips.com/topic/674250-slow-down-3pin-fan/
I wonder, could you wire in a resistor to bring the voltage down (and therefore the speed)?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683732
Wouldn't a resistor bring the current down instead of the voltage?
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683740
just get a adaptor for that,idk 12v molex to 7v 3pin for example
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683744
lots of ways you can use them.
System specs:
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683762
Wouldn't plugging the molex connector upside down(forcing it will probably be fine with a cheap adapter like that) give the fan 5v instead of 12v and slow it down?
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683804
Well, it's a bit more elegant to swap the pins since the connector is keyed to fit one way but yes, that would slow the fan down.
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683888
It's functionally the same, thanks for the answer!
https://linustechtips.com/topic/674250-slow-down-3pin-fan/#findComment-8683951
