1. Budget & Location
My budget is around Php 70-75,000. Location is in the Philippines, alhough some of the parts will be bought in Amazon via relative then sent to me, some will be bought in the link below:
https://tipidpc.com/useritems.php?username=PCHub
2. Aim
I want to play FPS games in 144hz like CSGO, Call of Duty, Dota 2 (sometimes), and Tomb Raider: Rise of the Tomb Raider. More than 60 FPS preferably. I have no intention of doing SLI/Crossfire. I'm also looking to use the rig as a development machine using Java so I'd like to overclock it to get every ounce of performance possible.
3. Monitors
A single 1080p monitor will do. Like I said, I'll play FPS so I want it smooth on 144hz.
4. Peripherals
I already have a keyboard and mouse. Windows too.
5. Why are you upgrading?
My old rig is already 4 years old and I have a crappy 738p monitor. Sold my old rig for money. I already bought a Cryorig H7 for overclocking and an extra WD Caviar Blue 1TB Drive.
I have a build part list I'd like you to check out. Please also note that the parts are limited here in PH, so I'm asking for a relative's help in sending over stuff from US.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($235.49 @ SuperBiiz) [Buying locally]
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  (Purchased For $0.00)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($121.99 @ Newegg) [Buying locally]
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($93.99 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($62.99 @ NCIX US) [Buying locally]
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($0.00)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($404.89 @ OutletPC)
Case: NZXT S340 Elite (Black/Red) ATX Mid Tower Case  ($89.99 @ SuperBiiz) [Buying locally]
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.49 @ SuperBiiz)
Monitor: Asus VG248QE 24.0" 144Hz Monitor  ($219.99 @ Best Buy) [Buying locally]
Total: $1308.82
Generated by PCPartPicker 2016-11-16 21:25 EST-0500
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/674026-oc-fps-gamingworkstation-build/
Plzz change the graphics card, rx 480 will do 1080p gaming, but won't give you more than 60fps with all eye candy turned on, on some games and a 144hz monitor is a waste of money when paired with this card, get a gtx 1070 or at least gtx 1060 6gb version and overclock it. Rx 480 is not a good overclocker, where as pascal GPU overclock like a beast. Or since motherboard chosen is a nice one, get 2x rx480 in crossfire to match a gtx 1080 when crossfire works, at a much lower price than 1080. For now gtx 1060 is your sweet spot for the budget, but get a gtx 1070 if u can.
Happy gaming :-)
  • 1 month later...
UPDATE: Okay so I managed to increase in budget. I also put an updated build.
Happy gaming :-)
Now I'm getting the GTX 1070 since the RX 480 seems like a waste of money if I'm getting a 1080p 144hz monitor.
