Does anyone know when the Ducky mini will be released as i have seen very little about this board. Also what other 60% boards are there on the market, all i can think of poker, pure, GH60, HHKB.
Desktop -  i5 4670k, GTX 770, Maximums VI Hero, 2X Kingston Hyper X 3k in raid zero.
Laptop - Lenovo X230 Intel 535 480GB, 16GB Gskill memory, Classic Keyboard Mod, Triple USB 3.0 Express Card.
https://linustechtips.com/topic/67364-ducky-mini/
I think it's available with ISO layout instead of ANSI, it was a project headed by Ducky Nordic I think.....I don't think tere's an ANSI layout Ducky Mini.
http://deskthority.net/marketplace-f11/ducky-nordic-keyboards-keycaps-projects-and-misc-stuff-t4718.html
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/67364-ducky-mini/#findComment-921887
damm, cant stand ISO after having typed on ANSI for my entire life. If you were getting a 60% now what would you get other that that HHKB in your sig(want one but the price tag is crazy and i would rather spend the difference on metal key caps).
https://linustechtips.com/topic/67364-ducky-mini/#findComment-922101
The reason I like the Ducky Mini is due to its back light, but ISO isn't for me either. Best bet would be a Vortex KBT PURE if you want back light, if back light isn't a 'must have', then your option is much wider. Look at Leopold FC660M (MX switches) or FC660C (Topre switches), Poker 2, TEX Beetle or a Filco Minila for example. The stock HHKB 2's in my sig have Topre dome/spring hybrid 'switches' and are generally more expensive than stock MX keyboards.Topre isn't for everyone though, so I'd suggest you start off with a good 60% MX keyboard.
Vortex KBT PURE
http://kbtrace.com/kbtpure/kbt-pure-60-mechanical-keyboard-blue-light-ansi.html
Leopold FC660M review
http://geekhack.org/index.php?topic=44310.0
Here're a couple of Poker 2 reviews from GH
http://geekhack.org/index.php?topic=44118.0
http://geekhack.org/index.php?topic=44068.0
TEX Beetle
http://geekhack.org/index.php?topic=46342.0
There are many other 60% keyboards, too many to list. But if a 60% backlit keyboard is something you want, then I know of only the KBT PURE. I've been told that Poker 2 would come with backlight as well, so I'm awaiting its release.
https://linustechtips.com/topic/67364-ducky-mini/#findComment-924268
i really want a poker 2 because i do not want to deal with the arrow keys that the arrow keys that the pure or the Leopold have. Also those aluminum cases on GH look amazing. The issue is that wherever i look does not have them in stock at least in blue switches and i really dont want to go around swapping stems and shit from other boards on that i can have a blue switch Poker. Feng used to have them but all he has left are red and brown switch ones.
https://linustechtips.com/topic/67364-ducky-mini/#findComment-924642
They will put an ANSI version out later in the year or beginning of next year.
My Stuff:  Corsair Obisidan 550D - Phobya Nano-2G 120mm x 5 - Corsair H100i - MSI Z77A-GD65 Gaming - Intel 3570K - G.Skill 8GBx2 1866 - EVGA ACX GTX 780 3GB SuperClocked(Step Up to 780 Ti) - Samsung 840 500GB SSD - WD Black 1TB x 2 - LG Blu-ray - ASUS VG248QE + ASUS PB278Q - Corsair M65 with MM400 Pad - Ducky Shine II MX Brown with Gray/White Keycaps - Corsair K70 MX Red - CoolerMaster Quickfire TK MX Brown - Ducky Pro2 MX Blue with Gray PBT Keycaps - Ducky Pro2 MX Clears with Gray/Blue PBT Keycaps - Ducky Pro2 MX Browns with Light Gray and White PBT Keycaps
https://linustechtips.com/topic/67364-ducky-mini/#findComment-927080
That's the problem, if the local keyboard dealership manages to get backlit Poker 2's in before that, I'd be all over it.....the Ducky Mini would be but a memory I'm afraid.
https://linustechtips.com/topic/67364-ducky-mini/#findComment-928927
  • 3 months later...
