Isn't Vault 88 the LSD experiment? Looks good to me.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/673441-vault-88-glitched/#findComment-8675418
I haven't played Fallout 3 yet.
https://linustechtips.com/topic/673441-vault-88-glitched/#findComment-8675463
1 minute ago, Donut2994 said:
It's fallout 4 DLC. Vault-Tec Workshop.
I know. Best choice is to make a copy of your saves. Verify the integrity and try again. If it doesn't work, you may need to look into Mod Organizer.
https://linustechtips.com/topic/673441-vault-88-glitched/#findComment-8675492
Oh, I thought you are confused, haha. I will make a copy and try it without any mod active.
https://linustechtips.com/topic/673441-vault-88-glitched/#findComment-8675495
Look into Mod Organizer as well. It'll keep your game's data and mods separate so that this doesn't (or not as often) as with NMM or manual.
https://linustechtips.com/topic/673441-vault-88-glitched/#findComment-8675513
