i want 2 use my old monitor as a 2nd monitor for multitasking so i bought a vga female to dvi so i can use it but i does not work i went in control panel and it does not come up in devices and in screen resolution it does not come up but if i hit the detect button another monitor pops up saying another display not detected, and i get the same in the nvidia control panel.
please help
https://linustechtips.com/topic/672791-check-signal-cable/
What adapter are you using specifically?
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669096
1 minute ago, kieran121 said:
That's the problem. The signal coming from the DVI-D connector is digital, and VGA is analog. Unless the adapter is active, it won't work.
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669114
well fuck. do you know any other way i can use this monitor it's vga only and the mobo vga does not detect it either
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669125
What motherboard are you using?
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669127
2 minutes ago, kieran121 said:
this
You can purchase a cheap video card to use as your video output.
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669148
6 minutes ago, kieran121 said:
yeah but that's the thing i'm saving for a beast of a pc
just get something like a gt 210 and use it if you really need a second display.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669171
What video card are you currently using?
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669202
evga 650ti 2gb
Depending on how you have it set up(for example if your current monitor is connected to the DVI-I connector), you can move your primary display to the DVi-D connector, purchase a DVI-I to VGA adapter(which won't be active because DVI-I also outputs an analog signal through the four additional pins in the square formation), or if you're using the mini HDMI connection, you can just get the adapter I mentioned above and connect the display.
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669234
i use the mini hdmi so i have 2 buy a DVI-I to VGA
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669244
is this it http://www.ebay.co.uk/itm/DVI-Adapter-DVI-I-24-4-pin-to-VGA-SVGA-Female-HD15-Converter-Connector-/401169582105?hash=item5d67920819:g:~r0AAOSwawpXrWHM
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669270
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8669277
On 08/10/2016 at 3:39 PM, Godlygamer23 said:
Yes, that should work.
i just got the new dvi-i adapter it came on like it should when i was changing the display setting so it extends i get an msg saying "out of range" i did a quick google search for it and it said run ur pc in safe mode but it is not there when  i boot my pc they have changed in win10 or something.
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8687840
In order to boot into Safe Mode, click on restart in the Start Menu while holding Shift. You should get additional options. There should be one about changing the behavior of the boot operation. This will give you the option of going into Safe Mode.
https://linustechtips.com/topic/672791-check-signal-cable/#findComment-8687905
