Okay i dont reallly know where to post this so here we go...
So im installing a Security System and im wondering which one to get.
Im looking at NewEgg mainly (Here)
I dont really know what to look for either, if you could help me with that to, it would be nice
P.S if this is the wrong Forum area please tell me; i will change ti
https://linustechtips.com/topic/672608-security-system-help/
How many cameras?
How long do you want the video?
How much do you want to spend?
All will work. Id personally buy ipcams and get a server to controll them as i already have cat 5 running everywhere and they only need a cat5 with poe(no seprate power cable
https://linustechtips.com/topic/672608-security-system-help/#findComment-8667534
2 minutes ago, Electronics Wizardy said:
How many cameras?
9-10 Cameras
Less Than 1,000
Not really sure how long i want the video
And thanks!
https://linustechtips.com/topic/672608-security-system-help/#findComment-8667554
Yes you need to know how long you want to roll, then reroll.
I'd say any system would work, but I'd want something where I can view everything on my cell and pc.
I remember years ago, I parked in behind a repair garage, tire running low needed air at 2am. No security, but owner saw me from his house on vid. So he had motion sensors.
I cant tell you how many times I watch The First 48, and they show crappy footage that is useless.
Or they find a cam and its fake or not working.
https://linustechtips.com/topic/672608-security-system-help/#findComment-8667776
if you got a whole sale place near costco BJ's ect they have good systems . i picked up a 8 camera system last summer for i think 400 . also you get some choice if you dont mind looking at a few locations you can get old school BCN connectors , wire think Coaxial wire or a system that uses ethernet wire . i learned the latter is simpler for outdoor runs . i personal would not buy it online its better to pick out it in person . most of this stuff is for company's or small businesses not someone doing their home with security cameras
do you need nightvision/inferred  ? what res do you want 1080p 720p or the HDd res  for the cameras .
with my system with all 8 running i get 1 month of saved video 2tb purple drive . dont know if all models come with crap drives in them . mine had a no name OEM hdd that wasnt even sata I or ment to run 24/7 .i currently only have 2 cameras running and last i check i could go back 6 months still . for brands lorex is what i have works very well so far the interface to control it via tv . but it works . before you buy one check reviews since you dont want to buy a crap Chinese knockoff  one .
saw above you want 9-10 of them so your stuck buying a 16 system unless you can get away with a 8 camera system . first link is a brand i have and it works well second one is the best i can find one is bnc other is ethernet cable . if you know how to make ethernet cable connections its that simple .
http://www.newegg.com/Product/Product.aspx?Item=N82E16881126291&ignorebbr=1
http://www.newegg.com/Product/Product.aspx?Item=N82E16881183084&ignorebbr=1
no hdd in second link one so add 200-400$ for a 2-4tb purple drive (X2?)
note for OP
something i found out bnc is not waterproof connections unless you spend stupid amounts on *(insert brand here ) cables meant for outdoor connections .
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/672608-security-system-help/#findComment-8667979
