I am looking for a new 15in gaming laptop and I could use some advice. I want a good screen with good color accuracy and as thin as possible with a gtx 1070 while staying away from U processors.
http://www.aorus.com/Product/Features/X5 v6
I really like the Aorus x6 v5. It's .90 in thick, light, has a 1070 and a 6820hk, 256gb nvme drive + 1tb mechanical, 16gb ram (plus the per key rgb keyboard looks cool). $2400 usd it’s pretty pricey though and one review said that the screen wasn’t that great.
http://www.sagernotebook.com/Notebook-NP8153-S.html
The Sager NP8153-S configured to match the Aorus would be $2059. It’s a bit thicker 1.13 in, heavier and a much smaller battery but looks compelling. Does anyone know if the screens are any good? I am having trouble finding reviews that detail the color gamut and response time.
Both do not have thunderbolt 3, should I really care?
Anyone have experience with the quality of either?
http://www.alienware.com/laptops.aspx
I really like the looks of the new Alienware 15 too, but it doesn’t have a numpad! I really want a numpad.
Any advice will be much appreciated, thanks!
https://linustechtips.com/topic/672527-help-sager-or-aorus/
I'd take the Aorus one, and please don't make the text so damn big next time.
My computers as of 2017/03
My Old PC
Dell Vostro 260 $150 2010
CPU: i3-2120@3.3Ghz, GPU: Intel HD Graphics 2000, ATI Radeon X1300, RAM: 4GB Axevir Budget Series, SSD: 240GB Radeon R7, HDD: random 250GB and random 160 GB, CASE: Crap from Dell, OS: Windows 7 Enterprise
My Current PC
Custom Build $1200 2016
CPU: i5-6600k@3.6Ghz, GPU: Sapphire R9 Fury, RAM: 16GB Geil EVO X, SSD: 240GB Radeon R7, HDD: Hitachi 500GB, CASE: Deepcool Kendomen, OS: Windows 10 Professional 64-Bit
Laptop
ASUS F8S $1150 2008
CPU: Core 2 Duo T7500, GPU: ATI 2400 Mobility, RAM: 8GB Mushkins, SSHD: 1TB Seagate Hybrid Drive, OS: Windows 7 Ultimate N and Windows 10 Professional
HTPC
MSi Cubi $200 2016
CPU: Pentium 3805u@1.9Ghz, GPU: Intel HD, RAM: 4GB Crucial DDR3L, SSD: 120GB Radeon R7
Other Laptop
HP 2210b $400 2009
CPU: Core 2 Duo T8100@2.1Ghz, GPU: Intel GM965, RAM: 2GB Hynix, HDD: Hitachi 160GB, OS: Linux Mint 17.3 and Lubuntu
*All Prices in the Canadian Dollar
https://linustechtips.com/topic/672527-help-sager-or-aorus/#findComment-8666667
The CLEVO, it's not a Sager, anyday.
http://www.notebookcheck.net/Schenker-XMG-P507-Clevo-P651RP6-G-Notebook-Review.172321.0.html
^ uses the same screen. Specs in the link above
The Aorus one is hot and loud and the size of the battery is used to compensate for having no MUX switch. The Clevo will get better battery run times due to the ability to swap from GSync and Optimus whereas the Aorus is always in GSync dGPU on mode. So yes, the Clevo is an easy winner. HOWEVER, if you have an unlimited bank account, repasting the Aorus and benching it would be fun to see.
Also don't buy from Sager. Buy from LPC-Digital.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/672527-help-sager-or-aorus/#findComment-8667535
