I built this pc on a budget of around $500 CAD
This I what I built
CPU:FX8350 4.4ghz
MOBO: Booster TA970
RAM: 8gb DDR3 Ballistix crucial tactical
GPU: HIS R9 280 ICEQ
PSU: OCZ 1000watt Xstream
Storage: Seagate 2TB HDDS
Case: Thermalteke V3 Black
DVD drive: LG DVD/CD burner
https://linustechtips.com/topic/672514-rate-my-first-pc/
I'd say not that bad considering your budget. Did you buy used?
Also you might consider getting a ssd for your os.
A 240gb or 120gb ssd is not much now and you just put your os there to speed up boot times.
Can you get a bit higher overclock? 4.4ghz seems a bit low.
https://linustechtips.com/topic/672514-rate-my-first-pc/#findComment-8666494
Im not sure i can see enough. The Camera was too far away when you took the Pictures.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/672514-rate-my-first-pc/#findComment-8666564
1 minute ago, xXATHERIALXx said:
My system needs 750watt min so I bought a 1000 watt used for $30
not sure where the hell you heard that from, but your pc does not need 750w. a good 500-600w is enough.
https://linustechtips.com/topic/672514-rate-my-first-pc/#findComment-8667263
The box for the 280 says so
it doesn't. they're grossly overestimated specs to account for rubbish power supplies. i've run an r9 280 on a cheapo 530w before and nothing happened, even with overclocking on both the cpu and gpu.
https://linustechtips.com/topic/672514-rate-my-first-pc/#findComment-8667318
