you can use cotton buds if you like, I wouldn't use cotton wool that would make a nasty mass.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/672487-thermal-compound-removal/#findComment-8666254
Yes, that's fine. I just use a paper towel or tissue.
https://linustechtips.com/topic/672487-thermal-compound-removal/#findComment-8666263
