2 minutes ago, MVPernula said:
Yeah there we have it.. 300w.
Okay what can we do here.. Can you give me a complete list of your specs?
I can almost guarantee that you need a new PSU to run your build but lets make sure.
i5-2320, 8GB DDr3, but this GPU is only 75w?
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663568
1 minute ago, iKl9kca said:
Needs 270 but I have 300? Also why is it booting then and only not displaying a image
Becuase it has enough power to get some things spinning, but not enough to actually start it.
If a GPU says it requires 400w to start.. You need at least that much to start it. I recommend a 500w for some headroom.
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663620
Sorry but did you connect the 6pin PCIE power cable?
11 minutes ago, MVPernula said:
But it also demands 400w to boot.
Calculating total powerdraw at IDLE gives 270w.
You need a new one.
270w on IDLE? For OP PC? You smoking?
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663621
For 8GB RAM, an i5 2320, RX 460, a prebuilt motherboard and 2 fans.. I'd say yeah, 270w would be pretty spot on.
EDIT: NOT IDLE SORRY. My bad. But still 300w in total for this is not enough. Even if he managed to start it.. His parts would die after a while with a PSU like that.
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663635
9 minutes ago, iKl9kca said:
No 6 pin it's a 460 also the reason I got it
RX 460 doesn't have a 6-pin?
Then I can kind of see why it doesn't start. You have a prebuilt mobo and a 300w PSU, getting a GPU much heavier than the AMD HD radeon 7450 wont let it start properly if the total powerdraw comes from the motherboard itself.
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663650
Yup. :P
You didn't mention 2GB Sapphire 460. :P
The 4GB one come with 6pin connector.
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8663654
3 hours ago, iKl9kca said:
That makes me so sad :( everything is so expensive I tried a 750ti sold it got this and now need a PSU rip
Do you have any other PC to test the card? We haven't rule out if the card DOA or not.
https://linustechtips.com/topic/672196-rx-460-issue/#findComment-8664117
