https://linustechtips.com/topic/672080-replacing-140mm-fans/#findComment-8662216
51 minutes ago, MrKat said:
Hey,
I have a CM Nepton 280l with the Jet fans. JET FANS. On max they are very loud. They are loud also on 700 RPM during idle. I was thinking to switching to quieter fans. Noctua NF-A14 PWM seems like fans to go. Any good quiet cheap alternatives?
Maybe try replacing them with Browns fans? They're pretty quiet, you just get some gentle sobbing on Sundays.
https://linustechtips.com/topic/672080-replacing-140mm-fans/#findComment-8662369
