Do I mount 3 fans on top?
wasiq614
Hello, so I have a nzxt h440 case and I decided to remove the 3 pre installed fans on the front and put an aio there I was wondering should I put the three fans that I look off on the top? And how should I put them? Thank you (:
2 minutes ago, Jed M said:
It's best to keep the radiator there.
The radiator didn't go well on the top that's why I put it on the front... My question still remins tho
The default fans should be good enough, especially with watercooling.
240mm AIO? If you use all 3 as exhausts, you will have negative pressure. Use 2 and run them at slower speed than AIO fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Top exhaust would be fine.
