these are my specs
CPU - 2500k @ 4.5Ghz(can go upto 4.8Ghz if needed)
GPU (new) - HD7970 DC2
GPU (old) - HD6870
MOBO - ASUS P8Z77V
PSU - Corsair CX600M
Windows 8
this has 3, 16x slots that will run at 8x,8x,4x when in use.
i have taken out the old GPU and have put in the new one and all is fine.
what i want to do is let the HD6870 fold even when im gaming or doing something else.
but the problem is as soon as put the old GPU on the second(8x) slot the PC BSOD as soon as it boots in to windows. not sure what is causing the error. it give a error code saying some thing about ".....exception not handled...." <----- i will edit this post as soon as i get that error again.
so is there any way to fix this ?
and if im posting this in the wrong section please let me know.
thank.
Should post this in the folding section or PM Whaler_99 .
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
dont think so this is about a problem with a gpu not about folding :)
but for the problem like you said post the error code and the .dump file and try using diferent pci slots and try using the 6870 in combo with new one but use the 6870 as primary
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
i did try using a different slot, but not 6870 on the 16x slot and  7970 on the 8x, i will try this
one one question how do i get the .dump file? i know such a noob question
c:\windows\minidump look there
-Adolf Hitler
attachicon.gifdump_file.html
this is the dump file from that time.
didnt try with changed slots yet.
ehm that might be the wrong dmp file (my fault) so could you look around in c:\windows if there is a file named blabla.dmp AND have you un-installed the vid driver and reinstalled it ????
-Adolf Hitler
yes i have re installed the drivers, anyway i think ill just put the old GPU on to a different PC. thanks for the help anyway
